Enables IPv4 routing or IPv4 broadcast forwarding for one or all VLANs. If no argument is provided, enables IPv4 routing for all VLANs that have been configured with an IP address on the current VR or VRF.
| ipv4 | Specifies IPv4 forwarding. |
| broadcast | Specifies broadcast IP forwarding. |
| vlan_name | Specifies a VLAN name. |
Disabled.
IP forwarding must first be enabled before IP broadcast forwarding can be enabled. When new IP interfaces are added, IP forwarding (and IP broadcast forwarding) is disabled by default.
The broadcast, ignore-broadcast, and fast-directbroadcast options each prompt with a warning message when executed while the IP forwarding on the corresponding VLAN is disabled. The hardware and software are NOT programmed until IP forwarding is enabled on the VLAN.
The fast-direct-broadcast and ignore-broadcast options cannot be enabled simultaneously. These are mutually exclusive.
The broadcast option can be enabled in conjunction with fast-direct-broadcast and ignore-broadcast.
The following command enables forwarding of IP traffic for all VLANs in the current VR context with IP addresses:
enable ipforwarding
The following command enables forwarding of IP broadcast traffic for a VLAN named accounting:
enable ipforwarding broadcast vlan accounting
The ipv4 keyword was added in ExtremeXOS 11.2.
The ignore-broadcast and the fast-direct-broadcast keywords were added in ExtremeXOS 12.0.
This command is available on all platforms that use the Edge, Advanced Edge, or Core license. For information on the licenses available for each platform, see the Switch Engine v33.1.1 Licensing Guide document.
